Hello, I'm having trouble with some shortcuts for setting end time and continuing and I don't understand if it's a problem from my part or some kind of bug.
I'm using the latest version SE 4.0.11
So, the only shortcuts that are working for me are the "set end time" and "set end add new and go to new" shortcuts.
When I use the following shortcuts, nothing happens. It's as if I used the "set end time" shortcut, it only marks the end time, but it doesn't go to next.
"set end and start of next after gap"
"set end next start and go to next"
"set end and go to next"
I just want to be able to set the end time of one line and create the next line in the waveform without being prompted back to the textbox as the "set end add new and go to new" does.
Isn't this possible? Or am I doing something wrong?
Thanks in advance for your replies.
Results 1 to 1 of 1
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 06:44 -
Can I set manual starting time of all timestamps in Subtitle Edit?
By Hariachka in forum SubtitleReplies: 1Last Post: 21st Feb 2023, 14:25 -
Subtitle Edit - Color Shortcuts
By rallia_dreamer in forum SubtitleReplies: 1Last Post: 12th Oct 2022, 12:44 -
Set subtitle to Zero in Subtitle Edit
By loninappleton in forum SubtitleReplies: 10Last Post: 19th Feb 2022, 15:19 -
Set subtitles to start at a specific time code using Subtitle Edit
By seorimpaek in forum SubtitleReplies: 1Last Post: 28th Jul 2020, 22:03
